EGFR独立的 AZD9291耐药机制
15889 29 longyangagent 发表于 2015-10-4 21:15:35 |
   研究发现 AZD9291耐药产生2类不同病例:her2和met扩增。有趣的是发生T790M突变的完全消失,在一个病例中,通过组织活检发现原发部位发生T790M突变而转移部位出现不同信号通路而产生耐药。建议联合her2或met抑制剂用药。
EGFR-independent mechanisms of acquired resistance to AZD9291 in EGFR T790M-positive NSCLC patients.
Abstract
BACKGROUND:
AZD9291 is an oral, irreversible, mutant-selective epidermal growth factor receptor (EGFR) tyrosine kinase inhibitors (EGFR-TKI), which specifically targets both sensitizing and resistant T790M mutations. This compound has shown outstanding activity, in a phase I/II (AURA) trial. However, despite impressive tumor responses in T790M-positive patients, acquired resistance to this drug limits the benefit of this compound. Mutations at the EGFR C797 codon, located within the kinase-binding site, were very recently reported to be a potential mechanism of resistance to AZD9291 in T790M-positive patients.
PATIENTS AND METHODS:
To identify potential mechanisms of resistance to AZD9291, we report here on two patients with resistant biopsy specimens that had been treated with AZD9291.
RESULTS:
We identified in two distinct cases, HER2 and MET amplification by FISH and CGH as a potential mechanism of acquired resistance to third-generation EGFR-TKI. Interestingly, this event occurred with complete loss of the T790M mutation. In one case, we observed a different molecular status at two biopsy sites (the T790M mutation at the primary site and wild-type T790M at the metastatic site with different pathways of acquired resistance to AZD9291).
CONCLUSION:
Our observations suggest that T790M-positive and wild-type T790M clones may coexist at baseline. AZD9291 efficiently suppresses the growth of T790M-positive cells, but a population of wild-type T790M cells at baseline will mediate the development of resistance, here via a by-pass pathway activating either HER2 or MET.
http://www.ncbi.nlm.nih.gov/pubmed/26269204
如有兴趣关注微信号longyangagent
36条精彩回复,最后回复于 2016-8-24 07:46
lxd0123  高中二年级 发表于 2015-10-5 10:11:19 | 显示全部楼层 来自: 上海浦东新区
前辈, 我理解这文章意识是野生790可以用过旁路激活,其实就是原发的790突变或许可以利用联合HER2和MET抑制剂来治疗
不对。 acquired resistance 获得性耐药  发表于 2015-10-5 11:20
butterflyxu  初中二年级 发表于 2015-10-5 15:15:31 | 显示全部楼层 来自: 中国
AZD9291耐药机制耐药后还可以有两种选择盲试吗?
联合her2或met抑制剂用药,这两种先后这么选择?联合还是9291吗?
文章的意思是9291+her2抑制剂或9291+met抑制剂,具体看自己选择(盲试)  发表于 2015-10-5 17:18
默默的生命抗争~正在学着坚强~似乎很难
康来  大学四年级 发表于 2015-10-5 20:43:02 | 显示全部楼层 来自: 广东佛山
不错的信息。
lxd0123  高中二年级 发表于 2015-10-5 22:02:15 | 显示全部楼层 来自: 上海浦东新区
又看了下 意思应该是790突变可以用9291控制,耐药会造成野生型的790则通过HER2或MET等旁路通道形成转移,主要是说了耐药造成的790突变和野生的790突变可以共存,因为在原发部位检测到的是790突变,转移部位检测到的是野生790
也反映了肿瘤发展的复杂性、多样性  发表于 2015-10-5 22:24
有可能,但不排除这些类型中原来就有野生的  发表于 2015-10-5 22:22
butterflyxu  初中二年级 发表于 2015-10-6 11:04:34 | 显示全部楼层 来自: 中国
T790是因为一代获得性耐药后产生的,那如果9291再次耐药,是不是说明T790靶点减少或消失,那一代靶点会不会有几率恢复可能呢?
如你所说,肯定可以回到一代。问题是这些也是一家之言,还没有得到广泛的认证。我们试想如果真这样,我们可以翻来覆去用药,治癌症就像治感冒。  发表于 2015-10-6 15:32
默默的生命抗争~正在学着坚强~似乎很难
yiyang  初中一年级 发表于 2015-10-12 15:22:06 | 显示全部楼层 来自: 吉林长春
学习了,谢谢分享
ordersshentu  小学六年级 发表于 2015-10-12 16:37:26 | 显示全部楼层 来自: 浙江杭州
该文的意思是说,(第一代TKI耐药后)T790M阳性和野生T790M可以同时存在,9291可以完全抑制T790M阳性,但是野生T790M缺导致MET或者HER2突变,从而临床上表现为9291耐药。如果在9291抑制阳性T790M的同时,联合其它可以抑制MET和HER2的药,可以抵制或者延缓9291耐药。问题是,MET或者HER2的抑制剂就不会耐药吗?
会的,也有研究如何解决met和her2的耐药问题,目前还不是考虑耐药的时候  发表于 2015-10-12 19:19
nbhstqw  高中一年级 发表于 2015-10-12 17:30:43 | 显示全部楼层 来自: 浙江宁波
9291耐药后的治疗,是需要好好去了解下了。
a121314  禁止发言 发表于 2015-10-13 16:05:21 | 显示全部楼层 来自: 河北保定
