多吉美单药治疗胆囊癌/胆管癌二期临床
4682 2 bluest 发表于 2012-5-18 22:44:23 |
Background: There are no standard chemotherapeutic regimens for incurable biliary adenocarcinomas. Gemcitabine and fluoropyrimidine- based chemotherapy results in occasional responses and a median survival approaching 6 months. Given the presence of b- raf mutations and overexpression of VEGF in biliary cancers, we initiated a study to evaluate the efficacy of sorafenib, a multitargeted tyrosine kinase inhibitor of c and b-Raf, VEGFR-2/3 and PDGFR, in pts with metastatic biliary cancers.
Methods: Pt eligibility included adequate organ function and no prior treatment for metastatic disease. The primary end-point was objective response rate (RR). Secondary endpoints were overall survival (OS) and progression free survival (PFS). A two-stage design was used to detect a difference in the null hypothesis of 5% response probability and the alternative 20% response probability. If at least one confirmed response occurred after the first 25 pts, another 25 were to be accrued. Sorafenib was administered at 400 mg PO BID continuously. A cycle was defined as 28 days of therapy, and radiological assessment was done every 2 cycles.
Results: 36 pts were enrolled during the first stage of accrual. 5 pts were ineligible. 52% were female. Median age was 57.8 years (range 33.8-81.5). Adverse events: 1 pt died with grade 4 supraventricular tachycardia and venous thromboembolism. Grade 3/4 toxicities were noted in 20 pts (66.7%) and included hand-foot syndrome in 4 pts (13%), while thrombosis/embolism, elevated liver transaminases, and abdominal pain were each seen in 3 pts (10% for each). Reversible posterior leukoencephalopathy syndrome, GI perforation, and GI hemorrhage were each seen in 1 pt (3% for each). 2 pts (6%) had an unconfirmed partial response and 9 pts (29%) had stable disease. 27 pts have progressed. Median PFS was 2 months (95% CI: 2-4 months). 14 pts have died, with a median survival estimate of 6 months (95% CI: 4-10 months).
Conclusions: Sorafenib did not result in a clinically significant objective RR in pts with gallbladder and cholangiocarcinoma but demonstrated an impact on survival that may be comparable to commonly used chemotherapy regimens.
http://www.asco.org/ASCOv2/Meeti ... mp;abstractID=31684
http://www.asco.org/ASCOv2/Meeti ... mp;abstractID=35266
结果不好,有效率低,中位PFS只有2个月。
2条精彩回复,最后回复于 2012-5-19 07:47
阿彦  初中二年级 发表于 2012-5-19 00:07:55 | 显示全部楼层 来自: 江苏南京
胆管癌有没耐药时间长点的药的临床,特罗凯有做过吗?
bluest  退休老干部 发表于 2012-5-19 07:47:34 | 显示全部楼层 来自: 北京
