《Hydrogen gas activates coenzyme Q10 to restore exhausted CD8+ T cells, especially PD-1+Tim3+terminal CD8+ T cells, leading to better nivolumab outcomes in patients with lung cancer》8 l% C4 J4 s$ G- x5 m/ Q
2 h+ u* n- ]3 L+ W4 i" V# f" @0 i
这是日本的一个O药联合或者不联合吸氢气治疗非小细胞肺癌的前瞻性随机对照试验。 m/ M" B& L: Y- W4 O8 q, J+ f
9 J' [. z c6 o1 y+ b
制氢机出气量等情况是这样:“The Hycellvator ET 100 (Helix Japan, Co., Ltd.) generates 1.67 l/ min hydrogen gas (hydrogen purity, 99.99%) by electrolysis. As measured by gas chromatography at Kureha Special Laboratory, the gas generated 680,000 ppm hydrogen gas and 320,000 ppm oxygen gas. Recently, hydrogen gas inhalation was used in patients with post-cardiac arrest syndrome, and adverse events were not observed”, V+ }+ `9 S/ q+ S _
, j8 K, ?( v% T$ L2 z
患者每天吸三个小时氢气。
! z9 t2 B t$ E) Y0 r
: M) l- {: S0 q) t* K60个月的随访,临床试验结果是:“Kaplan-Meyer analysis showed that the HGN-treated patients had a significantly longer OS than those treated with NO (Fig. 1A). Median survival time (MST) for the HGN-treated patients was 28 months, a length that is approximately 3-fold longer than that for NO-treated patients (MST 9 months) (Fig. 1A).”
8 B$ l2 a" A3 N + j0 s5 p# ^3 Q) L Z
联合吸氢组的中位生存期是28月,不联合吸氢组的中位生存期是9个月。
! M5 L5 c: d* l7 E8 C4 e( U) X5 @
2 G5 E/ v+ k V# y. W1 t& M! O研究者认为联合吸氢组疗效更好的原因是 “Hydrogen gas activates coenzyme Q10 to restore exhausted CD8+ T cells, especially PD-1+Tim3+terminal CD8+ T cells。”- E6 P- e! [+ i5 V7 X) g8 T
% d: |/ Q6 t1 Z4 \6 q9 c3 _
研究者在临床试验基线和过程中检测了入组患者的血液辅酶Q10的含量极其变化。
& j+ ~" y5 v u) n
4 A- ^8 n" j- m% x+ ~“We measured the CoQ10 concentration in the 35 HGN-treated patients with stage IV lung cancer and investigated its association with OS. The cut-off value was found to be 0.985 µg/ml (ROC curve; AUC=0.803, Sensitivity=83.3%, Specificity=81.8%, (Fig. 2E). Further, the 35 HGN-treated patients were stratified as having high (>0.985 µg/ml) and low (<0.985 µg/ml) CoQ10 concentrations. There were no significant differences in the clinico-pathological factors between patients with high and low CoQ10 (Table III). Patients with high CoQ10 had a significantly longer OS than those with low CoQ10 (Fig. 2F). MST of patients with high CoQ10 was 25 months, while that of patients with low CoQ10 was 8 months (Fig. 2F).”& \ r) _3 V: j' C
* W# E' y2 h# P) r! r# D
“Following hydrogen gas treatment, the concentration of CoQ10 was increased in 19 (46%) of 41 patients (Table IV). Hence, we proceeded to calculate the rate of change of CoQ10 by hydrogen gas treatment (CoQ10 ratio=CoQ10 concentration after treatment/CoQ10 concentration before treatment) and classified patients by high- and low-CoQ10 ratio using the cut-off value (1.175) (ROC curve; AUC=0.710, Sensitivity=75.0%, Specificity=66.7%) (Fig. 2G). Patients with a high-CoQ10 ratio survived significantly longer than those with a low-CoQ10 ratio, as shown in Fig. 2H. MST of patients with a high CoQ10 ratio was NR (not reached to 50% overall survival), while that of patients with low CoQ10 was 9 months (Fig. 2H).”
- O9 J; ~8 `' ~1 Y4 q/ A# j # {. I$ [& A& m3 f
血液辅酶Q10浓度高的患者,用icb的OS更长。
8 [( |. J4 O3 S' S7 b' v! i- P |
