关于PD1在胆管的使用,请bluest给个建议
5894 13 tracyzhou 发表于 2015-2-26 22:23:04 |
bluest  退休老干部 发表于 2015-3-4 22:09:55 | 显示全部楼层 来自: 北京朝阳
tracyzhou 发表于 2015-3-4 17:52
我主要看胆管的对靶向的耐药时间非常短,一旦停下来好像就会长得很快,需要不停尝试到有效药控制
是啊,胆管癌还是没有找到关键点
lamya  初中一年级 发表于 2015-3-10 13:31:33 | 显示全部楼层 来自: 辽宁沈阳
有效缓解的办法真是太少,急人。
小金牛  小学六年级 发表于 2016-12-18 23:53:49 来自手机 | 显示全部楼层 来自: 山西忻州
请问后续有使用pd1吗
tk0083  小学三年级 发表于 2017-1-8 17:06:51 | 显示全部楼层 来自: 美国
Program Death 1 Immune Checkpoint and Tumor Microenvironment: Implications for Patients With Intrahepatic Cholangiocarcinoma
Abstract
Background
Program death 1 (PD-1) and its ligand (PD-L1) have been identified as potential therapeutic targets for solid and hematologic malignancies. The current study aimed to assess PD-L1 expression in intrahepatic cholangiocarcinoma (ICC) and relate clinical outcomes to its expression.
Methods
Formalin-fixed, paraffin-embedded tumor specimens were obtained for patients undergoing surgery at Johns Hopkins Hospital between 1991 and 2011. Immunohistochemistry was used to assess PD-L1 expression in tumor-associated macrophages (TAMs) and within the tumor front (TF).
Results
Of 54 tumor samples analyzed, 34 stained positive for PD-L1 expression on TAMs (TAMs+), and 39 stained positive for PD-L1 expression on cells within the tumor front (TF+). The TF+ patients were less likely to present with metastatic lymph nodes (N1 patients: 26.7 vs 7.7 %; p = 0.011), whereas all tumors with intrahepatic metastasis failed to demonstrate staining for PD-L1 around the tumor front (p = 0.020). Patients with tumors shown to be TAMs+ were less likely to present with multiple lesions (35.0 vs 8.8 %; p = 0.017). Patients with tumors exhibiting PD-L1 expression around the tumor front demonstrated a worse overall survival than TF patients (p = 0.008). Multivariable analysis showed that patients with tumors staining for PD-L1 in the tumor front had a 59.5 % reduced survival (TF− vs TF+: time ratio, 0.405; 95 % confidence interval, 0.215–0.761; p = 0.005).
Conclusion
Expression of PD-L1 was noted among a majority of patients, and PD-L1 expression within the tumor front was associated with a 60 % decreased survival. Future clinical trials are necessary to assess the safety and efficacy of anti-PD-L1 therapies among patients with ICC.
这边的数据是在54个样本里面34个TAMs为阳性,39个TF+为阳性
